Version: latest
IndustrialClaw 1.0.0 installs as a set of containers on a single edge device.
Official support covers the Advantech hardware and OS configurations marked Official under Supported platforms.
Supported platforms​
Supported hardware and model providers for the 1.0.0 release:
HardwarePlatform and OSOllama (Local)OpenAI-compatible APIGitHub CopilotSupport status
AIR-075NVIDIA Jetson AGX Thor · JetPack 7.1 · Ubuntu 24.04●●●Official
AIMB-294NVIDIA Jetson AGX Thor · JetPack 7.1 · Ubuntu 24.04●●●Official
DS-015Compatible Linux + Docker environment△○○Technical compatibility
AIR-021Compatible Linux + Docker environment△○○Technical compatibility
AIR-030Compatible Linux + Docker environment△○○Technical compatibility
AIR-055Compatible Linux + Docker environment✕○○Technical compatibility
SymbolDefinition
●Validated and officially supported
○Technically compatible
△Conditional / configuration dependent
✕Not supported
The Downloads page lists the release that matches each hardware profile and its validation status.
Host prerequisites​
ItemRequirement
Device RAM4 GB free is the platform's own floor and does not include a model. A device that runs the default local model (qwen3.5:4b-q4_K_M) should have at least 16 GB of RAM or unified memory.
DiskAbout 5.8 GB for the core images; about 8 GB for the Ollama image; about 3.4 GB for the default qwen3.5:4b-q4_K_M model. Plus room for Logs, Sessions, Materials, and Outputs to grow.
NetworkRequired during installation to pull images. Once a local model is in place, normal operation does not need outbound connectivity.
