Version: latest
Roles and Limits
The platform enforces these limits; exceeding one produces a refusal with a stated reason rather than a queue.
ItemLimitNotes
Total accounts50Includes the bootstrap admin.
Additional Administrators10The bootstrap admin is not counted.
Concurrent signed-in accounts3The bootstrap admin can always sign in and does not consume a slot.
Session lifetime24 hoursThe session ends and requires a new sign-in.
Idle sign-out30 minutesA screen nobody touches signs itself out. The timer runs from the last pointer, key, wheel, or touch event, not from the last network request.
Sub-Agents per device10The Main Agent is not counted. Updating an existing Agent is not affected by this limit.
Agents running Tasks at once5A Task for a sixth Agent is rejected, not queued.
Concurrent Tasks per Agent1A busy Agent does not accept another Task.
Task Markdown size64 KBPer Task definition.
Material ZIP size1 GBExtracted into the Agent's materials/ directory.
Agent package size20 MBPer Agent ZIP.
Two roles exist, and a role cannot be changed after the account is created:
OperationAdministratorUser with assigned AgentUser without assigned Agent
View AgentsAllMain Agent and assigned AgentsMain Agent only
Create, update, or delete an AgentYesNoNo
Create or delete a Task definitionYesNoNo
Start or stop a TaskAll TasksTasks for assigned AgentsNo
View Task RunsAllRuns within the permitted scopeNo
View Logs and SessionsAllTasks that User startedNo
Create accounts, assign AgentsYesNoNo
View AuditYesNoNo
Use Main Agent ChatYes, sessions isolated per accountNoNo
Change retention or OverlayFSYesNoNo
Only the bootstrap admin—the account the device ships with—can delete another account or force another account to sign out. It cannot itself be deleted, disabled, or changed to another role.
